Hello all..1997 Toytoa Avalon, 260K, manual air conditioning. I recently replaced the evaporator coil, expansion valve, and receiver/drier. Evacuated, tested, and charged with 24 oz. of R134A, which is slightly short of the required amount of 28. Compressor will not come one. I jumped it out from the relay and it will work, but will not come on automatically. I traced it to the lack of ground at the clutch relay.
Now the embarrassing part. I discovered after i reinstalled everything that i forgot to reinstall the thermistor. After doing some reading i thought that the thermistor was used only on the Auto AC, not the manual AC; however, looking at the wiring diagram, it looks like the thermistor "contributes" to the ground on the AC magnetic clutch and sensor.
I still somewhat suspect the pressure switch, as you are supposed to be able to jump out the pressure switch and the compressor turn on, and this is not happening (i.e. when i jump out the switch the compressor does not run).
Have checked the fuses (2 - 1 at the driver left side and 1 beneath the glove box) and the heater relay (beneath the glove box) and all checkout ok. Also traded out relays on the clutch relay with no luck.
#1 question: is the missing thermistor contributing to the problem?
#2 question: anyone know what the resistance readings should be across the thermistor when it is hot/cold??
thanks to all
thanks to all
