As you can see, the filter is still in the wrapper. I'm guessing the red spots are just bleed through from the dye?? Also, if you look along the bottom of the filter, the black stuff (glue??) is up quite high on the filter. I'm use to paper filters or cone aftermarket filters. Does this all look normal?? Thanks
