Originally Posted By: DrRoughneck
Originally Posted By: FastLane
You can use iridium plugs in anything you want.
Let me rephrase my question: will it work well?
The short answer here is "Yes, it should work fine"
The long answer is:
Regardless of the type of plug (copper, platinum, double-platinum or iridium), all plugs deliver spark essentially the same way, and they all utilize a copper core. The difference in 'type' is the electrode material and how well it holds up over time, stays clean, etc..
The major difference here being - how long the plug can stay in the engine and continue to deliver a good spark. Iridium is incredibly durable, and is very good at self-cleaning, so it last a LONG time, as evidenced by the 300,000 on these plugs, and the factory iridium plugs I took out of my Fusion @ 215,000 miles (which still looked pretty darn good).
As a rule, Iridium is not any better at conducting electricity or delivering a strong spark than Platinum, which is no better than nickel, etc.. Given plugs for a specific application SHOULD all deliver spark equally in that application, when new.
So yeah, iridium should work well.
