Originally Posted By: Skid
Originally Posted By: JimPghPA
it's simple. Find out the cooling system capacity (your local Napa has a book that list the capacity). Add half that amount in pure 100% coolant. Then finish the fill with distilled water.
That will be close enough (if you drain both radiator and block), but it will be below 50-50 because volumes are not additive. Chemistry 101.
Please explain ?
If your system holds 4 gallons, and you've flushed with water...then you put in 2 gallons of pure A/F, then how does that end up less than 50% ?
Please explain ?
