Originally Posted By: 02SE
Originally Posted By: ZeeOSix
Searched all over the web and couldn't find anything about FJRs having plated cams. I've never seen any camshaft that was plated; they are normally case hardened to keep the wear down.
Top end looks good Scout1.
I've seen a lot of plated cams, having built and rebuilt thousands of engines (if including the racing engines I've worked on for the last 14 years or so). Anyway, it sure looks like a plated cam experiencing flaking of the plating to me. But I haven't had a modern FJR apart.
At any rate, if it is failed plating on the cam, the lobe won't be wiped out overnight.
I don't doubt there's been chrome plated camshaft lobes used on something. I've never seen it on any Japanese bikes I've worked on. I doubt Scout1's FJR has plated cam lobes.
If the lobes are plated, there should be a distinct difference in the look of the lobe compared to the rest of the camshaft (like shown below on a plated follower and shift fork). They wouldn't plate the whole camshaft, just the lobes.
I had a 1984 Honda VF700 that ate cams just as described in this article and got them replaced under warranty, but I recall Honda couldn't say exactly why they failed. The single actuator for two valves was a bad design to start with, and I recall that adjusting the valves on the V4 with the Mickey Mouse special tool was a royal pain. This article explains why.
http://www.motorcycleproject.com/text/v4_cams_what.html
