So.. I'm curious.. A trans uses trans fluid, engine uses engine oil, rear end uses 90w..etc...But then you get into a motorcycle and one Lube does two different purposes.... What got sacrificed
What if instead of trans gears there was a ring and pinion plus engine that needed Lube.. What would u use then? Is it a byproduct of the type of gear tooth? The chemical makeup of the oil.. Or. Something else all. Together...
Just looking for general conversation and discussion on this topic
