As per signature, i use G11 IAT coolant from wolf.
That was their oil selector's recommendation.
After 3 months i start to dig deeper and found that oil selectors of other companies recommend either HOAT or OAT (Mobil,motol,Valvoline,kroon oil,enoc)
Only wolf recommends IAT!
Owner's manual doesn't mention any coolant specification. or type.
My knowledge that both engine and radiator are aluminium.
No available information if there are copper parts/lead solders in cooling system.
My concern is:
when i change current G11 coolant,is it ok to use HOAT coolant instead?
After draining cooling system, about 2 liters of current coolant remain inside engine even after pumping air.
My concern is:
