Originally Posted By: hank2
The model years for the Toyota/Scion warranty enhancement for excessive oil consumption was extended to some newer models.
Most notably, the Scion XB, through the last production year, 2015.
The VIN cutoff number on the XB is: JTLZE4FE?FJ 069331
The warranty enhancement goes to 10 years or 150,000 miles from first date of service.
In either case, you have to flunk (pass?) Toyota's oil consumption test of at least a quart within 1200 miles.
I did not know this. Thanks.
So far no consumption on my 2012 xB, but only 35,000 miles on it so far. Will keep an eye on it for sure.
I know the consumption problems start around 60,000 from what I have read.
I plan on having this car for a long time, and even if it starts it will probably be well past the warranty period.
Hopefully, me using a syn oil and 5000 mile OCI will help.
My truck uses 1 qt every 1500 miles and have no problem adding oil to it as needed, so no big deal.
I also just found when looking up my VIN on the Toyota website that my xB has a recall on the passenger side airbag (Takata inflator). No fix yet, recall issued January 9, 2017.
As for the OP, if it has been using oil (> 1 qt every 1100-1300 miles) for a while, just keep driving it the same and it will meet the criteria for rebuild.
I would be wary of the dealer, the visit you had to them already did not seem to go well. Checking the dipstick before sealing it would be a good idea if possible.
