I had the dealer check for a parasitic loss as well as an alternator test as my battery became weak at about a year old. I think it sat on the lot too long (sulfated). I replaced the battery since the charging system seemed to deliver to proper voltage and then had them run the test. Everything checked out fine with them. They tested the battery and came back with 761 CCA on a 500 CCA battery. Is this pretty normal for a battery to show that much more capacity? This was from the printout that looked like a Midtronics test. Battery is made by East Penn 51R.
