It would appear that when I clean my engine, water sits in the valley, and the knock sensor is underwater. There are no indications of any problems with this one other than the high water mark well above it. It is several hours and a number of gaskets and o-rings to get to this point. Should I replace it and the short harness while I have it apart, or just let it go and see if it lasts another 10 years? The inside of the connector was wet, which can't be good, but I can clean that. Apparently, the short harness is a common failure point, maybe the sensor itself is waterproof.
Whenever I wash the engine, I drive it and let it run long enough for the engine fans to come on, which happens above 200 degrees, but apparently, there is not enough heat in the valley to evaporate the standing water, degreaser, oil, etc. that falls in there.
The OEM part is around $200, that is probably what I would use.
I'm kind of surprised there isn't a drain passage of some sort. Maybe going forward I will stick my oil extractor tube in there to suck out most of the water.
