Ford uses an RTV that you have to have the bolts tightened within 15 minutes of application or else you have to take it all back apart and reapply. This is on the timing covers on a lot of the newer V6 engines. Fortunately with most of them you have to pull the engine to do the timiing cover so access isn't an issue.
