Originally Posted By: wtd
Originally Posted By: mk378
Always measure refrigerant by weight when charging into an empty system. The only way to know for sure you have the proper charge is to start from empty (vacuum) and put in the specified amount by weight.
This is what I always do. I don't try to recharge by pressures and I always start from an empty system. I use a 30 lb tank and a refrigerant scale to do mine. I also use some stuff called Nylog to coat the o-rings and threads of any joints that I open up to help prevent future leaks and to help the connections come apart easier the next time.
I also always replace the receiver/dryer and all o-rings in the system if possible and the compressor if it's the source of the leak. I also usually replace the condensor because most newer ones are almost impossible to flush and they usually don't cost much these days. I only want to do the job once.
Lots of good advise here. Certainly NOT the only way, but the best for anyone who's doing it as a DIY project.
Also, DO NOT coat the condenser with oil. Oil is only for the compressor. It is carried through out the system, but should remain in suspension within refrigerant. Coating any heat xfer surface, EVAP or condenser will reduce its ability to remove or reject heat.
