Finally discovered the cause of some weird intermittent system operation:
This from May 24, 2016:
Quote:
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
CHKDSK is verifying files (stage 1 of 3)...
Read failure with status 0xc0000185 at offset 0xc4720000 for 0x1000 bytes.
File record segment 72832 is unreadable.
File record segment 72833 is unreadable.
File record segment 72834 is unreadable.
File record segment 72835 is unreadable.
The total allocated size 0x4f3000 of attribute of type 0x80 and instance
tag 0x1 in file 0x11ea1 is incorrect. The expected value is 502000.
Fixing corrupt attribute record (128, )
in file record segment 73377.
150528 file records processed. File verification completed.
313 large file records processed. Read failure with status 0xc0000185 at offset 0xc4720000 for 0x400 bytes.
4 bad file records processed. 4 EA records processed. 57 reparse records processed. CHKDSK is verifying indexes (stage 2 of 3)...
180434 index entries processed. Index verification completed.
0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 3)...
150528 file SDs/SIDs processed. Cleaning up 642 unused index entries from index $SII of file 0x9.
Cleaning up 642 unused index entries from index $SDH of file 0x9.
Cleaning up 642 unused security descriptors.
Security descriptor verification completed.
14954 data files processed. CHKDSK is verifying Usn Journal...
35578952 USN bytes processed. Usn Journal verification completed.
Adding 1 bad clusters to the Bad Clusters File.
Correcting errors in the master file table's (MFT) DATA attribute.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
122561535 KB total disk space.
30527316 KB in 88909 files.
56424 KB in 14955 indexes.
4 KB in bad sectors.
256459 KB in use by the system.
65536 KB occupied by the log file.
91721332 KB available on disk.
4096 bytes in each allocation unit.
30640383 total allocation units on disk.
22930333 allocation units available on disk.
Recently:
Quote:
CHKDSK is verifying files (stage 1 of 5)...
332 large file records processed. 0 bad file records processed. 4 EA records processed. 57 reparse records processed. CHKDSK is verifying indexes (stage 2 of 5)...
183014 index entries processed. Index verification completed.
0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 5)...
150528 file SDs/SIDs processed. Cleaning up 140 unused index entries from index $SII of file 0x9.
Cleaning up 140 unused index entries from index $SDH of file 0x9.
Cleaning up 140 unused security descriptors.
16244 data files processed. CHKDSK is verifying Usn Journal...
35368904 USN bytes processed. Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
Read failure with status 0xc0000185 at offset 0xbfb5c000 for 0x10000 bytes.
Read failure with status 0xc0000185 at offset 0xbfb60000 for 0x1000 bytes.
Read failure with status 0xc0000185 at offset 0xbfb61000 for 0x10000 bytes.
Read failure with status 0xc0000185 at offset 0xbfb68000 for 0x1000 bytes.
Read failure with status 0xc0000185 at offset 0xbfbd9000 for 0x10000 bytes.
Read failure with status 0xc0000185 at offset 0xbfbdd000 for 0x1000 bytes.
Windows replaced bad clusters in file 55403
of name \PROGRA~1\Palm\PHOTOD~1\ui\DGUI\IMG_DI~1.UI.
Read failure with status 0xc0000185 at offset 0xb8834000 for 0x10000 bytes.
Read failure with status 0xc0000185 at offset 0xb8839000 for 0x1000 bytes.
Windows replaced bad clusters in file 58752
of name \Windows\winsxs\MSIL_P~2.233\PRESEN~1.DLL.
Read failure with status 0xc0000185 at offset 0xaffc6000 for 0x10000 bytes.
Read failure with status 0xc0000185 at offset 0xaffd1000 for 0x1000 bytes.
Windows replaced bad clusters in file 85474
of name \Windows\System32\DRIVER~1\FILERE~1\PR5FB4~1.INF\I386\BRIO04AB.BCM.
150512 files processed. File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
20974257 free clusters processed. Free space verification is complete.
Adding 8 bad clusters to the Bad Clusters File.
38349988 KB in 95174 files.
57960 KB in 16245 indexes.
36 KB in bad sectors.
256535 KB in use by the system.
83897016 KB available on disk.
20974254 allocation units available on disk.
Chkdsk was run again on 2/21/2017 3:20:36 PM. No errors found this time.
Next I ran WD HD checker:
What's odd however it that the HD passed all SMART tests with green arrows! Odd that...
Using Mozbackup, I BU FF & T-bird data (after extensive junk/trash/old msgs removal), then stored them onto my old WXP HD connected via USB.
Then I BU the OS, personal data & W7 install backup partitions using Acronis and stored them on WXP HD. Fortunately this completed w/o errors and is residing on a separate HD that I verified using CHKDSK.
Now my task is to make the WXP drive my primary and install the three partitions onto it, then install it as the new C:/ inside the Optiplex SFF case after removing the current C:/, correct?
WD HD diagnostics said it could attempt a repair but data might be lost. It advised running the repair from DOS (cmd?) post-boot.
Seeking guidance here as it's been awhile since I've had to do this.
Reading up on how to use Event Viewer and find CHKDSK logs has really paid off. Glad I caught this now before the HD failed to boot.
Q: if CHKDSK "repaired" current C:/ why does WD diagnostics "fail" it? Different tests? Repair didn't work? Please advise. TIA...
that you continue.
Recently:
