It's routine on MGs to "regenerate" the cans by opening them and dumping out the charcoal, lighting it on fire, and letting it burn out. You then put it back together with fresh top and bottom foam.
The purpose of lighting it on fire is to burn off any gasoline that's hanging around after 40+ years. Obviously it's done in a safe place well away from the car or anything else flammable. For the less adventurous, you can refill with course aquarium charcoal.
BTW, on MGs(with the exception of the very last models) you have a single can located where the pedal box would be on a right hand drive car. They have three connections-one from the gas tank top to scavenge vapors(used with an unvented cap), one from the carb overflow vents, and one to supply make-up air to the crank case.
It's nice, though, to look back to a time when you have a part performing basically the same function in the same way as on modern cars, but that can be fixed so easily.
