Originally Posted By: IllinoisSparky
Is it possible that this was just break-in wear reducing over time?
Never used Redline, so not here to defend them, but if you calculate the oil changes to all be 3500 miles, like the one at 25,900 miles, It looks like a fairly linear drop in lead. Assuming linear wear change related to miles, which is probably not accurate. And doesn't account for how it was driven each OCI. For instance, lead dropped 8 between the 3500 OCI, and the 4300 OCI on Redline, so hard to figure causes for drops/increases on UOA numbers.
Here is what I came up with after changing them to all be for 3500 miles (Report miles - adjusted Lead level):
3500 Lead 29
4300 Lead 21
4245 Lead 32
3530 Lead 28
3145 Lead 15
3300 Lead 8.5
4247 Lead 5
3064 Lead 3.4
If the 3530 mile reading was the first M1, it only went down 4 when adjusted for miles, from the previous Redline. It does go down pretty steady after that.
If the M1 is working for you though, no need to go back. Save the price difference for other things.
I think I may be coming down with Bitog Derangement Syndrome....
I'm not sure if you are looking at the reports correctly. That is not a linear drop in lead from where I started using Mobil 0w40. Its more like an exponential drop.
DH
