Good Question.
I would have to review drill bit coatings, but I believe most drill bit coatings are solid nitrided coatings, I.E., the bit is immersed in an ammonium/metal salt and then heated.
From the paper:
Quote:
3.1. Structure and the Dispersing Stability of TiO2 Nanoparticles
Representative TEM images of both kinds of nanoparticles are shown in Figure 1. It can be found that the appearance of pure TiO2 was a hollow sheet with the size of around 100–200 nm (Figure 1a), while the average size of surface-modified nanoparticles and thus the size distribution is in the range of 50–100 nm (Figure 1b).
Similarly, dispersed (MoS2 moly) powders in grease form layered sheets between rotating and sliding parts.
From the paper:
