Working on replacing radiator, hoses, thermostat. All are original.
The truck seems to run at 180F all the time according to the scanner. It's a Ford, so the coolant temp. gauge is of no use. From what I'm seeing, there are two original equipment thermostats - 195 and 180.
Unless the truck is driven super hard, it will get a bit of white residue on the oil cap. Typical of these 5.4L engines.
I'm not sure what the theromstat is, but I'd like to go with a 195. I will be doing some heavy towing with it soon, but most of the time it doesn't see that type of use. I'd feel better with a 195 thermostat in it, but not sure if that would hurt it at all in anyway.
So what temperature would you run? I'm a warmer-is-better person
