Originally Posted By: clinebarger
Did you price GM elbows? You can take the O-ring off & install them on the Dorman elbows, You have to watch buying small parts as the assemblies may be cheaper.
New GM elbows would have lasted a long time.
I've got new GM elbows on order just in case something goes wrong with the Dorman elbows. I thought about taking the O-rings off the GM elbows, but I'm afraid of stretching the O-rings out. So I've got GM elbows, GM elbow O-rings, and Dorman elbows on order. I thought about having the ACDelco gaskets on order to back up the Fel-Pro gaskets, but that would be too expensive. Right now I'm giving some serious thought into going to the salvage yard to pull off a lower intake manifold. I watched some guy on YouTube pull the lower intake manifold on his car and it was completely unusable because of massive amounts of corrosion.
Just use the GM elbows!
People blow everything out of proportion, The 3.8L had the LEAST amount of issues compared to the 3.1L/3.4L 60 degree V6 & 4.3L/5.0L/5.7L Vortecs far as lower manifold gasket problems & corrosion around the water ports.
If your car has been maintained......Your lower intake will be fine.
