Ok, ordered my 4 quarts of kreen and got my free aerokroil can.
I'm running a dose of lubri-moly MOS in maxlife syn blend 5w-30, I'll push to 2,500 miles then do a piston soak, followed by BG109 then a drain. I'll do a run of Maxlife 100% Syn with the kreen 1,000 & 1,000, piston soak, use the seafoam TB port-injection head cleaning method with an italian tune up (but using the new Gumout Tune-up with a [censored] of PEA in it) and then drain and see where we end up.
Thanks for the heads up on the kreen - I knew about Kroil, my dad had a few small squeeze cans from 30+ years ago around, but had no idea they still existed.
