Changed out the front diff fluid. It was a nice grey milky fluid and I only got 1qt and 8oz out. Put 1qt and 24oz back in before it started to run out the fill hole. So it seems it was under serviced.
I also serviced the T case. It took just about 2 full qts before it started running out as well. It is so easy to do. Might just do it once a year.
I didn't get to the rear. I didn't do my home work to find out it has a reusable gasket. So I'll get it some time this week while the weather is warm.
I did put it on my lift and I think it is a wee bit to heavy. I did manage to get the wheels off the ground but the lift didn't want to move very fast so I didn't push it. Just enough clearance to get under it while it sat level to service everything.
