Originally Posted By: Char Baby
Since your vehicle is still under the factory warranty, you may want to stay with a regular replacement air filter. My brother-in-law(45 year diesel mechanic) explained to me that a factory air filter already flows more air than the engine needs. So as the filter gets dirty, it still flows sufficient air to the engine. And the OE or OE replacement aftermarket air filter traps more harmful dirt than a high performance air filter.
IMHO, these AEM or K&N aftermarket air filters don't work for the daily driver. Not all by themselves anyway!
Over the years, I have put them in several vehicles only to notice nothing in the way of any performance or fuel economy benefits in any of the cars over many years of trial and measuring(MPG & 0-60, 30mph-50/40-60 etc.). Nothing I could feel either!
An aftermarket AEM or K&N air filter may work or add to the performance of an engine in conjunction with other items such as an aftermarket exhaust system, and other engine mods. However an AEM or K&N by themselves(IMHO), is the equivalent of adding extra PSI(by itself) to your tires in hopes of getting extra MPG or (in certain cases)higher octane in hopes of extra performance.
Others may feel different.
AND
Originally Posted By: circuitsmith
I suggest you stick with a standard filter and install a filter minder, like this:
https://www.amazon.com/WIX-Filters-24801-Filter-Service/dp/B0014BI1KA
It will tell you when your filter is really ready to change.
Since any air filter works more effectively as it collects dirt you'll maximize average efficiency.
You won't need to open the filter housing as often, potentially disturbing dirt and letting it into the intake.
When the restriction reaches 11" is a good time to change the filter, which is about 3% drop in pressure.
I have 38k miles on the current filter in my Matrix and it's at 8".
These two posts say it all. They are the best advice on an 'everyday' basis. On similar lines, the only thing I'd like too add is that unless you really need every last CFM, in which case you want open ITBs in a huge sealed plenum, the standard paper filter in the standard box is the most favourable option.
But that doesn't take in to account the fun we can have with experimenting! Removing helmholtz chambers in the inlet tract, bigger diameter piping, smooth walls, elliptical entries, thermal insulation, moving MAF up/downstream, and after all that effort it would be a shame not to test various filters. If you want a cone, the S2000 OEM filter is high efficiency and cheap, AirAid, Dryflow, ITG, there are lots of options to choose from.
Experiment and have fun, but keep any parts you remove I case you want to go back to stock in the future.
