Originally Posted By: Langanobob
I wonder also if that oil vapor/tiny oil droplets getting into the intake tract might to some small extent be acting as an upper cylinder lubricant.
I've thought of this many times. I don't think the small amount of oil vapor does anything except cause inefficient combustion and isn't as clean and powerful vs if it was getting clean fresh air and clean top tier fuel and nothing else inside the combustion chamber.
I think if it wasn't for emission regulations, engine wouldn't have EGRs or any other nonsense being sent into the combustion chamber except the necessary components needed to make power only.
