Today while doing another drain/fill on the Sedona, setting the final fluid level, getting fluid burped in my face, etc... I recall reading consistently on the internet that overfilling an automatic transmission can, amongst other things, cause higher pressure within the transmission. Pardon me if I'm missing something, but isn't this impossible? Unit pressure is determined by the pump and seals, and could certainly DROP if underfilled, but in no way INCREASE if overfilled. It's not like the transmission operates on gravity feed pressure or anything. Pressure doesn't increase simply because the reservoir the pump is drawing from increases in volume. Someone tell me I'm sane
