Originally Posted By: artbuc
Tegger, you had me almost 100% convinced you knew how the MM worked!
I had myself convinced, too.
My OM does not mention anything about time...it only mentions engine revolutions, starts, stops, mileage, etc. I talked to my dealer's Service Department and they assured me my MM will not trigger B4 based on months. Now, I would be the last person in the world who would assume an Acura dealer Service Department knew anything about my car, but I pass their comment along fwiw.
I did some checking on my end, and it appears that your guys are correct. Months are not part of the Maintenance Minder.
Apparently this is why the annual oil-change, 3-year brake fluid change, etc, are not part of the Maintenance Minder, because the Minder does not consider months, and those items are determined solely by months.
