Well, I just finished changing the Anode Rod in the Hot Water Tank.
The Tank is 11 years old and had the 'original' rod.
It didn't look to bad and most of it was still there (like 99%)
It did have some mineral deposits that may have been insulating it from the water.
My suggestions for anybody contemplating doing this.
1) I had to buy a 'segmented' Anode Rod.
2) I bought an Electric Impact Wrench from Harbor Freight and used it for removing the old Rod.
3) I hung (2) plumb-bobs from the ceiling joists and was able to confirm the Tank did not move any.
4) I bought a 3/4" NPT tap to clean up the threads.
5) I also installed a 3/4" Ball-Valve in the drain with a fitting for the garden hose.
Problems: There was only (1)
I had a water leak where I screwed in the Anode Rod (using tape and paste).
I ended up putting more tape on it and I had to make it super tight.
After several attempts, it stopped leaking.
Maybe that's why the Manufacturer makes them so tight in the first place.
But I'm no plumber.
For the next time, I would like to find a 'sealant' that may do a better job so I won't have to
screw the Rod in so tight. (that must be stretching the threads abit).
But I'm no plumber.
