Oldsmobile had the motor that was going to take out the competition in 1971-1972.
https://m.youtube.com/watch?v=3tSKRCFJhpg
https://m.youtube.com/watch?v=QNgZ4q2EWBs
Published on Jan 21, 2016John Beltz was Oldsmobile's chief engineer in 1964 and one of the prime movers of the Toronado and 442 project. Beltz was promoted to Oldsmobile general manager at age 43 in 1969 when Harold N. Metzel retired. Beltz passed away in May of 1972 from cancer at the age of 46.
John Beltz is leaning on a dual fan 455 Olds and posing with other experimental Olds engines that never saw production.
Here are descriptions of these engines:
1. The 0W-43 all aluminum 455 with 4 valve per cylinders, four overhead cam Weber engine. With a redline of just under 8,500rpm it was originally conceived for CAN AM racing. At 3,000rpm it put out 300hp and at 6,000rpm registered over 600hp. The top output recorded for this engine in the Lansing dyno facility was 700 real hp at 6,800rpm. Tests were run with both carbueration and fuel injection. The block was cast from Reynolds 356 alloy and fitted with pressed-in dry steel cylinder liners for the Forged-True 12.20to 1 pistons. Billet steel connecting rods by Carillo was used along with a forged steel crank. The engine weighed in at 50 pounds lighter than the production 455 motor! It was developed at the same time as the ZL-1 Chevy 427 motor.
2. The W-43 4 valve per cylinder 455 developed by JOHN BELTZ , LLOYD GILL , JOE JONES AND FRANK BALL. Rated at 500-550hp with a single Rochester Quadrajet on an aluminum manifold. Constructed with both cast iron heads and block and with aluminum-alloy block and heads 75 pounds lighter than the conventional 455 production engine. Engine featured four valves per cylinder with narrowed angles for a super efficient combustion chamber design, central spark plugs and could easily be adapted for chain for gear driven overhead camshafts. 455 engine had 4.625inch cylinder centers, a 4.125 bore and 4.250 stroke. Making use of the 3inch main bearings and 2.50 inch rod journals, the engine was fitted with a specially prepared cast crank fitted with SAE-1140 forged steel rods, forged 10.20-to-1 pistons which rode on Morraine 400 bearings. Four bolt main block boasted 2 additional 5/8inch drain holes. Four valve heads featured 1.750inch intake valves (SAE-8640 steel) with 22 degree stems and 1.375 exhaust (214-N stainless steel) with 15 degree stems, special Stellite seats, bronze alloy guides, o ring plug tubes, 14mm spark plugs, 3/8 inch pushrods and aluminum rocker arms. (Of all the experimental Olds engines, this one came the closest to production and there are photos of this engine in street gear. MAY 71 HOT ROD MAGAZINE features some of these engines and the sadness of the Olds engineers of that time of how they would never be released.)
