GM 3800 color under oil cap
Well, you saw in my previous post what I said about it seeming like the throttle body sitting too high. Admittedly I am an amateur, but I thought everything and the bracket were on correctly. The benefit claimed by that mani is that it comes with a metal sleeve for the port known to melt.
Next time I would choose the Dorman 2nd design mani, where the fix is something about having air gap around the port or something or other, but no metal sleeve.
I have not heard complaints of the Dorman "2nd design" and it's probably the most commonly used. You should have no issued with the Dorman.
