My 4Runner with the 3.4L 5VZFE just hit 350,000 kms. I picked this up 3 years ago with 300,000 kms and have been running Pennzoil Platinum 5W30 ever since. It does not use any noticeable oil between 8000 km OCIs. In this time, I've done ALOT of work to the truck just to bring everything up to spec maintenance wise. Engine wise, I've replaced the rear main, crankshaft, and camshaft seals as preventative maintenance (when I did the timing belt + clutch). This summer, I'll be doing the valve cover gaskets. The only other engine seals I can think of that are left are the oil pump + oil pan, but those are not known to be problematic so I probably won't go out of my way to replace those unless a problem arises.
So since 80% of the rubber seals on my old engine are new, is there still any value in using high mileage oils? From my understanding, high mileage oil's primary benefits are for softening old rubber seals. I've posted a UOA here a while ago and the conclusion was the engine was still in very good condition.
