Manual Window -Winder Problem
The manual windows on my 1986 car have been getting stiff for a while, and last week the drivers side jammed open. The bottom of the glass is held in the window winding mechanism by a silicone rubber sealant which tore free, causing the glass to drop out of the guides. I can put it back but if i wind the window down more than about a quarter it jams on the way back up
As you wind the window further down, it pulls further away from the winder mechanism at the back, and moves out of the slider channel at the front.
I have actually bought very strong sticky black silicone rubber sealant here in the past, that might do the job, but I can't remember what brand it was, and probably wont be able to buy the same stuff again. I have some red automotive RTV that I could try but it doesn't seem to have as much tensile strength, so will probably not stay in.
It might try tying some fishing line across the top of the glass to help pull it down and take some of the strain off the sealant, though it may not be possible to feed past the bottom window seal.
Duct tape/Duck tape over the silicone might also help
I can lubricate at least part of the wiper mechanism with chassis grease, silicone grease, or anti-seize, and it might take some of the strain off the winder handle (these are getting brittle and will be hard to replace) but wont affect the tensile stress on the sealant, so wont stop the glass pulling out of the bracket.
To do that, it might help more to lubricate the window guide channels, but I'm not sure what to use. I'm thinking maybe silicone grease, a wax, or a soap. Somethimg like graphite powder or a Teflon-based grease might be better but I can't remember seeing either of them for sale here. Perhaps working some teflon plumbers tape into the guide would help, though it wouldn't be likely to stay in place for long.
Any suggestions?
Any suggestions?
