Originally Posted By: SatinSilver
Originally Posted By: SirTanon
Well, I've been outbid on the Charger, and I don't plan on re-bidding. Thank you all for your input.
So now he's relisted it and I'm bidding on it again. As far as I can tell, it's in good working order and in good physical shape. Guess we'll see.
Looks like the sale on the Charger fell through since the reserve wasn't met.
Actually, it had a 'Buy-it-now' price of $1650, which I suspect someone did without really looking at the pics. There's nothing in the listing itself that says "Engine Knock" - Only the one picture shows it, backwards, in the driver window, in a poor-quality picture.. so I wouldn't be shocked if someone didn't look hard enough at the pictures and just thought "Sweet! A 2006 Charger for only $1650!"
With the Caddy it appears to be a donated vehicle.
Yep - that is it.. and the listing lists it as "Runs and drives" so I feel that bidding around $350 should be safe. I also looked up the vehicle history, and it has no wrecks, and it's passed emissions.
Originally Posted By: Ramblejam
Be careful.
Clean-title, run & drive, privately owned vehicles without damage (normal wear/minor dents & scratches) end up there for a reason. That's not to say you can't find something good, but it takes a little due diligence and luck. If you live in Phoenix, and the vehicle is at a yard there, it'd behoove you to go inspect it before auction date so you have a better idea of what you're getting into.
Yep! My birthday is Sunday, so I'm taking Monday off at work.. part of Monday is going to be spent visiting the location that it's being stored and giving it a once-over. The keys are in it, so I should be able to start it and get an idea of it's true condition.
Regardless, good luck!
Thanks!
