Hi Everyone,
Hoping someone might be able to provide some assistance. There are MANY owners reporting groaning issues from the limited slip rear diff on the 16+ Camaro SS. This issue seems to crop up for most people within a few thousand miles. It happens in colder weather only (below 50 deg F, give or take) and happens only for the first few turns when the vehicle is cold.
GMs "solution" for this has been to advise dealers to drain and refill the fluid with their OEM limited slip gear oil. Owners are reporting that this approach improves the issue for a while but that it generally comes back. Some owners have also received new diffs and many of those replacement parts also end up with the same issue.
From researching here on BITOG, I believe the OEM oil is this one here: Link
I took the liberty to build a google docs spreadsheet comparing the published specs for the OEM fluid and compared it against the specs that are available for aftermarket options. As you can see, I was looking at several fluids marketed to the commercial semi truck market since I am sure the diffs for these vehicles are expensive and reliability is critical. Not to mention, some of these trucks are running super long fluid change intervals, which I'd assume would require a very robust fluid.
At any rate, what I discovered seemed to be quite interesting. It appears that the OEM fluid that GM is using is rather substandard in terms of viscosity. The google docs sheet is here: google docs
I would appreciate any assistance that could be provided interpreting this data. Also, I realize this is a long shot, but I am trying to figure out the maker and more details about the diff in the car. This information does not seem to be readily available. The part number seems to be specific to the Camaro only based upon a part number search using GMPartsDirect. I realize that Eaton is one of the bigger OEMs for GM diffs. I have emailed them using their customer service webform to find out if they are the supplier but I have low expectations for hearing back from them with anything useful.
By the way, at the moment, I am leaning towards using Mobil Delvac 75w90. I have not decided which friction modifier to use.
thank you!
thank you!
