Doing an underbody inspection on my van the other day, and I realized that my rear main control arms have cracked bushings (where the arm bolts to the unibody). The only replacements I see are complete arms, running $65+. Since the rest of the arm is just stamped steel and in fine shape, I'd like to just find a couple bushings and press them in myself (maybe even poly ones?), but I have no idea where to look. They are solid filled with rubber, no odd gaps, etc. Just a hollow 'dowel' in the middle that allows a bolt to pass through. Any ideas?
