If your trans is like that of my 2013 Avalon hybrid (which is like the Camry hybrid which is like the Prius trans), I did the usual BITOG OCD, and drained it at about 9300 miles which is when I bought the car. I used WS then. It was probably not necessary then, given there are no clutches, but...
Fast forward 30k later, and I decided to use Redline D6 as a long term ATF. They make top drawer stuff, and I sleep better. My car, my call.
I didn't notice any difference in performance, but didn't expect to given it's a "gearless" CVT, but one that uses conventional ATF. I asked Redline about that after what I read on their website. I had assumed a CVT is a CVT, which is true except when it's not
Changing the ATF on my hybrid is like changing manual transmission oil. There is a drain plug and and a fill plug. Both are accessible under the car. Not the easiest to do, but I don't plan on doing it often which is why I went with Redline. It's a bit of a PITA in that you have to get the car up on jackstands to be pretty level, then drain the old fluid, and add the new fluid till it comes out the fill hole.
One of these years I'll master a fluid line exchange, I guess.
I bought the Redline given it seems to have better high temp specs. All that said, use what you prefer. As long as it meets mfgr specs you're good, which Redline does in spades.
Don't fall for the bogus fear "they will do a chemical analysis on the ATF and discover it isn't WS and will void your warranty" (right after they drag your car out of the service area and set fire to it).
