Miles on Oil 1,100
Miles on Engine 1,100
Factory Fill
No Makeup oil added
Sample Date 2/20/17
Blackstone Comments:
This is a nice first report for your Harley. The high copper and silicon readings aren't troublesome,
since readings like these are perfectly normal for the first few oil changes from a new engine. Copper shows
wear-in of brass/bronze parts, and the silicon is from harmless sealers. Both should improve nicely over the
next few oil changes. No moisture, fuel, or other contaminants were detected, and the trace of insolubles
shows excellent oil filtration and low oxidation. Averages are based on ~4,700 miles of oil use, so try
running long next time.
Aluminum 4
Chromium 0
Iron 11
Copper 66
Lead 2
Tin 4
Molybdenum 91
Nickel 0
Manganese 4
Silver 0
Titanium 0
Potassium 3
Boron 273
Silicon 35
Sodium 5
Calcium 672
Magnesium 652
Phosphorous 727
Zinc 937
Barium 1
SUS Viscosity @ 210°F 87.3
cSt Viscosity @ 100°C 17.33
Flashpoint in °F 440
Fuel % span>
Insolubles % TR
Antifreeze% -
Water% 0.0
IN: Amsoil 20w 50, Amsoil Filter, Amsoil Primary fluid, Amsoil Transmission fluid.
Factory Fill
No Makeup oil added
Sample Date 2/20/17
Aluminum 4
Chromium 0
Iron 11
Copper 66
Lead 2
Tin 4
Molybdenum 91
Nickel 0
Manganese 4
Silver 0
Titanium 0
Potassium 3
Boron 273
Silicon 35
Sodium 5
Calcium 672
Magnesium 652
Phosphorous 727
Zinc 937
Barium 1
Fuel % span>
Insolubles % TR
Antifreeze% -
Water% 0.0
