As to the general question of molecular weight, there is only a narrow range of molecular weight PIB's suitable for fuel additives. BASF is one of the major suppliers of these PIB's and will give a blender a chart of which PIB's to use and at what treatment levels are recommended.
As far as OTC fuel additive suppliers, it is unknown as to how much PEA or PIB they may contain.
There is a level of PIB such that there is a point of diminishing return.
In my own experience, PIB comes in the form of a solid and one must dissolve it in n-Heptane at a ratio of approximately 80 mL of n-Heptane per gram of PIB, and then determine how much should be added to fuel, so a lot of calculations have to ensue in order to determine proper treatment levels.
