Originally Posted By: Diesel16
Originally Posted By: mazdamonky
Fram ultra or Fram tough guard. The AC delco or Wix are good if you don't mind losing some filtering efficiency.
Just curious but how is the better filter which is the wix filter here going to lose filtering efficiency? Please explain your claim. I remember a few years ago when everyone on this forum hated fram because of the cardboard end caps and the glue issue on the filter element itself. How is it that everyone loves them now when they are pretty much made the exact same way? Just curious is all. Personally I prefer the better filters like Baldwin, Hastings, Purolator, Wix, Mann
Regular WIX/NAPA Gold is 95% @ 20 microns. WIX XP/NAPA Platinum is 50% @ 20 microns.
Fram Ultra and Fram TG are both 99% @ >=20 microns. Fram Ultra holds more debris than the TG, that's why the Ultra has the 15K vs 10K use rating for the TG.
So fram made a major turn around then especially in this forum? Fram use to be hated on here. What do you guys thing of the regular orange can fram with the black grip on the bottom? Currently I use wix and baldwin filters on my car. Do you believe they are over kill on the car? Do you believe the fram filter would filter the oil a lot better then the baldwin or wix? I was always told Hastings, Baldwin, Wix where superior to fram, mobil 1, bosch filters. Especially from what I use to read on this forum a few years ago. From what I understand fram was horrible when Honeywell was making them. So who makes them now?
The Fram EG (orange can) is their lowest tier filter, and is rated at 95% @ =>20 microns and good for up to 5,000 miles. The TG is the next step up, and the XG is their top filter. The EG efficiency is the same as the regular WIX/NAPA Gold, but those may be able to go longer use interval. Not sure if WIX even rates their regular filters for use period, probably just claim they can do the OEM filter change interval.
There's nothing wrong with the EG if used as Fram recommends.
