At the end of next month, I am going to be using my dad's infrequently used truck ( as in, I last drove it in August and it has been sitting since) to tow my Jeep ~500 miles on a trailer.
It's a 01 F350 with 5.4L engine and 5 speed manual. 58000 miles I'm not sure what the towing capacity is (I think 8500 or 9500) but I should be well within the limits of it. The truck itself is extremely rusty, but the frame checks out as of last inspection. It doesn't get driven in the salt - obviously, since it doesn't get driven, so it shouldn't be too much worse.
What should I be looking at on this?
I am planning on replacing the radiator (has a pinhole leak or two), thermostat, radiator hoses - original, belt -also original, PS lines that are super rotten and probably checking the rear driveshaft U Joints. And an oil / filter change.
It recently had a lot of work put into it including - new brake lines hard/rubber, new pads/rotors/calipers/backing plates/shoes/parking brake cables, ball joints, front wheel bearings, front u Joints, spark plugs, changed AT fluid in the manual transmission and the AT fluid in the transfer case.
Is there anything else I should be looking at? The truck is always filled with ethanol free gas and the proper amount of Sta-bil.
It wouldn't be so much a thing but the truck sits all the time so who knows what it may need.
Any other suggestions!?
