My understanding was that by preheating the throttle body, it would heat the air/fuel mixture enough to help it vaporize in cold weather. That would reduce smog during cold weather. This is one of the reasons that many carb and TBI V8 engines had a coolant passage inside the intake manifold underneath the carb or TBI unit. Also, I think heating the throttle body was also an alternative to using air cleaners which had snorkels routed over the exhaust manifolds.
This was less of a problem with inline engines which had the intake and exhaust manifold on the same side of the engine. Radiant heat rising from the exhaust manifold was often enough to aid in preheating the cold air/fuel mixture.
