Originally Posted By: kschachn
Originally Posted By: Vikas
It is Honda crank bolt! This is the bolt which laughs at 300 ft-lb gun and makes the DIY cry with frustration. You are talking about well in excess of 200 ft-lb of final torque here.
I confess to not understanding the reluctance to buying a proper crankshaft pulley holder and then a 3/4" breaker bar and socket from Harbor Freight. That is what I have for both my Toyota and my Honda vehicle, and coupled with a short piece of pipe I've never had an issue with getting the bolt out even the first time. It wasn't even that difficult really, and you're not banging on the drivetrain with an impact wrench.
Use the same tools to reinstall it (with the first torque as you specified) and you're done. As a DIY person, no need for impact wrenches nor for upgrading your compressor or an aux tank. Seriously it isn't that hard.
Also, I've never seen a Honda FSM specify an initial torque and then an angle for that bolt. You're sure about that, right?
I have the Honda pulley holder, breaker bar, etc, etc. I could not budge it. If all else fails I will use a much bigger cheater bar. I am not as young and strong as I used to be. I have seen videos of young beefy dudes who could not budge that mother. Honda actually put out a service bulletin warning techs about this bolt. Yes, that is exactly what the FSM says.
