Originally Posted By: chrisri
If you are an atheist then there is possibly this car's ECU is under occasional alien control.
They probably use Occam's Razor, which is basically that the simpler explanation is the more likely one. In this case, could be bad master cylinder, bad transmission, optical illusion or a few other possibilities. Alien control is probably last on the list.
