As the title says I've got a roadblock. I have a 2002 WJ with 4.0 with a 242 transfer case.
Quick useful knowledge of 242 Tcase:
4Part-Time(4PT) = traditional 4HI locked transfer case
4Full-Time(4FT) = 4wd without locked transfer case so front can spin at independent rate
So back in December there were icy roads and snow so I put it in 4FT. Heard a slight faint grinding. Put it back in 2wd and all is well so I kept it there.
This past week got snow again so put it back into 4FT and got a very loud grinding noise with any sort of throttle. I'm in college so I don't have the time to look at it myself. Luckily so commute so I got my trusted mechanic to diagnose it.
As I suspected the Rezeppa joint at the transfer case end was toast. He called me today and said the boot was fubar and debris is in the joint but was honest with me saying he cannot 100% undoubtedly tell me that is what is grinding. He also said the shaft had some slop in it when rotating it.
In 2wd it does not make any noise or none that I can tell (should probably turn the radio down more). I tested 4pt before I dropped it off and I did not hear that loud grinding noise. I'm fine with the fact the Rezeppa joint is toast but it concerns that I only hear this in 4FT. Is this Rezeppa joint the likely culprit because the shaft still spins in 2wd and 4pt. Another friend of mine said the Rezeppa joint is grinding hard in 4FT because of torque bias or something like that. Does that have any merit? He said it could be the chain but since I hardly use 4wd and only 139k miles with no abusive off-road use he finds it hard to believe it would be a chain.
Now I have a couple of options as far as the front driveshaft. I have a fixed yoke at the dana 30 and the Rezeppa at the tcase.
I can either get:
1. Bobo brand Rezeppa joint 70-120 bucks off rockauto depending on manufacturer
2. Whole new stock driveshaft (380-400 bucks ehhhh don't like this option)
3. Get a new double cardan shaft and a yoke for it at the tcase (400 bucks) comes with Spicer 1310 greasable u joints
93-95ZJ double cardan will work but can't find any so that is out of the question.
Cannot use a WJ v8 double cardan as it is only 32" where mine is 35" and I'm on a 2.5" lift.
I appreciate anyone who can offer advice and help.
Thanks!
I can either get:
Thanks!
