Here's a very nice trick I got off a guy on one of the Ford truck sites. To replace the fuel pump on a full size van you have two options that I know of. The first is to drop the fuel tank. This was pretty much out of the question for me as the truck was sitting outside in the snow and not running, with a 3/4 full fuel tank.
Or.........Cut a hole in the floor and swap out the pump. (Kudos to WVVan for this great idea.) I eyeballed the pump location with a tape measurer and cut a couple 1 1/2 inch holes on the inside with a hole saw. Then I could see good enough to sketched out where I wanted to cut. Drilled a bunch of 1/8 inch holes along the line, and cut it out with an air hammer and chisel.
$143 to NAPA for the pump, gasket and strainer. 3-4 hours of work and it started up like a champ. Made up a cover with some sheet aluminum I had, sealed it with silicon and screwed it down. Now I have a nice convenient access panel if I ever have to get in there again.
