The Fusion turned 200K today. This car has been the most reliable vehicle I have ever owned. I change oil every 10K using M1 0-20AFE, and the engine uses no oil between changes. Engine and trans(drain and fill every 30K with M1 ATF) perform as well now as when I bought the car with 38K. Few parts have been replaced. No rattles and car handles very well.
Parts:
2 water pumps
Front and rear brake pads
Only suspension parts replaced was one front strut
One air pump and one sensor for fuel evap system
Replaced one panel on the front drivers seat
Replaced the accessory belt and tensioner pulley
Replaced the engine coolant thermostat
Replaced a sensor for the AC
Replaced the VC gasket
Parts:
2 water pumps
