i drank the cool aid
SD - South Dakota
Figured that it is only money, so I picked up some Amsoil XL 5w30 for the expedition.
I've used about everything else and I always get high metals, so I figured there is no harm trying something else.
I'm expecting great things ....
Ok, not really.
But I can compare amsoil to castrol edge, Napa synthetic, Mobil 1 HM.
Honestly, the only reason I haven't tried it earlier is cost. But I now get the preferred customer pricing so I got it for $25.xx per gallon, which ain't bad. Still %25 more than WalMart prices, though, which has always been the deal breaker for me.
So.... I drank the cool aid ....
Originally Posted By: 4WD
It's Kool Aid Breaux ...
I think autocorrect bit me .....
Originally Posted By: Red91
What metals are showing up in particular?
Aluminum and iron. Both are far higher than normal and have been since I bought the truck.
Originally Posted By: Donald
I see no sense to buy any Amsoil oil except their top shelf oil.
Clearly there is better oil at Walmart than Amsoil XL oil.
Perhaps, but I'm only going 7,500 miles. Their top line oil would have been wasted on such a short interval. As too would have anything "better" at WalMart.
If nothing else it will offer another data point.
Went and looked at Amsoil site - the 10w30 XL looks interesting with a 3.3 HTHS & real low NOACK ...
If you always get high metals, then it sounds like your trend is flat, which, for UOA, is more important than actual values, for the most part.
Originally Posted By: tig1
What are the metals numbers?
Code:
OIL Castrol 5w30 Castrol 5w30 Trop 5w30 NAPA 5w20
Edge Edge Artic Synthetic
Gold Bottle Gold Bottle SynBlend
MILES IN USE 9,060 9,980 4,989 6,447
MILES 158145 149,085 125,086 114,429
SAMPLE TAKEN 06/16/16 01/14/16 10/23/14 06/01/14
Metals (ppm)
IRON 71 88 10 45
CHROMIUM
LEAD
COPPER 3 4 1 2
TIN 2
ALUMINUM 12 19 4 22
NICKEL 1
SILVER
TITANIUM 21 20
VANADIUM
Contaminants (ppm)
SILICON 11 12 8 10
SODIUM 24 18 17 278
POTASSIUM
Additives (ppm)
MAGNESIUM 154 278 14 118
CALCIUM 1770 1990 2044 1792
BARIUM 1
PHOSPHORUS 637 648 690 627
ZINC 667 755 761 730
MOLYBDENUM 66 69 15 6
BORON 62 58 70 9
Contaminants
WATER (%)
Coolant No No No No
Physical Tests
Visc (cSt 100C) 9.0 8.9 8.9 9.0
TBN (mgKOH/g) 1.4 2.4 2.6 2.5
I dont know about flat ....
Aside from the one outlier, they are just "not stellar"
I'll have another one to post here in a few weeks.
It looks like the Phillips product produced the best numbers, and I wonder if the metal is indicative of upper cylinder wear. No copper so bearings aren't suspect, perhaps too the higher iron and aluminum is indicative of good cleaning? I'm still new to reading UOA's, but its my understanding that constant brand change/formula differences keep trends from establishing, and also can lead to good cleaning
Originally Posted By: DoubleWasp
That Trop Arctic really seemed to knock down that metal.
Yeah it did!!
That's true in the respect that his engine is not getting any worse. But there are documented cases of some oils in some engines producing more metal.
I'm expecting great things ....Ok, not really.
Welcome to the club! I'll be interested to see the UOA once it comes out. If the Amsoil doesn't make a difference it looks like you should go back to the Trop Artic!
After reading the thread title, I thought you bought something from Snap-on.
Nice!!!!!
