Originally Posted By: rooflessVW
Originally Posted By: Trav
Originally Posted By: Kira
I've seen some 12 point stuff said to be for Volkswagens...is that what you mean? Sorry I don't have the exact words. Kira
http://www.metric-threaded.com/browse.aspx?id=856
I scratch my head and wonder why, every time I come across these fancy fasteners. Is it some engineer that wanted to make a statement, or is looking to cash in on specialty tool sales, or just trying to make someone else's life a bit more difficult one day. Why wouldn't a traditional hexagon bolt head work?
The fastener pictured is a traditional 12pt, or double hex (120° corners). It allows for thinner sockets (barely), finer indexing for tools, and also allows for more applied torque.
VW uses XZN, which is also called triple square (90° corners). It's a different solution for the same problem.
OK thanks, that makes sense. I have a pretty well stocked tool box, and haven't come across anything I couldn't remove yet. Here's my rub. We've all seen Torx fasteners holding taillight lenses in, where a simple Phillips screw would serve the exact same purpose, or calipers held in place where you needed an Allen wrench/socket and a 6 point hex head would do the same thing and simplify the job a bit. IIRC I have U bolts holding the rear U-joint to the differential in my van that has 4 nuts which are very similar to that holding it in place, it came from the factory with it. That is what prompted my comments.
