Originally Posted By: Ramblejam
Originally Posted By: Lubener
You can drill a small hole (1/16 inch) on the flange of the thermostat to allow any trapped air to easily slip by
Such modifications are ill-advised, and not terribly well thought out. Here's the Civic thermostat:
Notice anything that's already present on it?
Not all stats have that hole and it has worked for me for a long time with engines prone to air pockets.. So I do not believe it is ill advised, unless you drill a 1/4 inch hole in it.
