Originally Posted By: italian68
I have seen a slight puff of blue smoke once or twice on startup after sitting for a few days or more, so idk if the rings are stuck. Just replaced the spark plugs (there's 16 of them). Would like to avoid the hassle of a piston soak. Pcv is new.
Is the PCV aftermarket, or an OE part? Aftermarket can be real junk, and actually cause oil consumption. I'd also try a piston soak and see if that helps any. Good luck.
