It's probably fine in the primary. I use Rotella T myself. But I've ALWAYS used gear lube in the trans of all my Harley's going all the way back to 1981. I know HD says 20w-50 is ok, but that's a fairly recent thing. They used to specify gear lube and to me it makes sense. Transmission gears shear lubricant, and gear lube resists shearing.
Yes, Im sure its fine using the Mystik too, the Formula+ is a simple mineral oil and the Mystik is beefed up mineral oil. The reason the beefed up part isnt need in the transmission and primary is because no combustion takes place.
Im not from the same camp in using gear lube in a transmission.
I know A LOT of people do and that is fine, me, I follow the manual just as I would my expensive cars. Some gear shift cars call for gear lube, some call for a special manual transmission oil and many, many call for regular motor oil.
I just select what the manufacturer calls for, my 2014 HD calls for motor oil in the trans..
I'm sure that gear oil or motor oil will be good enough to make our transmissions last at least until one of us buys a new Milwaukee Eight
Ha! Yes!
But ... you know ... I told my wife the 14 Road King will most likely be my last and Im going to keep it forever ...
I kind of meant it ... at the time. Yes, now that new M8 power plant. I hear it is awesome but Im still enjoying my RK way to much to even want one (and expend a bunch more money) yet again who knows... I have the good sense to NOT take one for a ride, though I suspect the people with the SG, RG will appreciate the extra power more being the RK is lighter then the others.
I am hooked on the Road King, if replaced it will be another with the M8, right now though, no compelling reason for me, love my bike as it is right now!
