Ok, I've had this Moto G4 for a month now (?). It would go a couple of days on a charge initially, but now it seems to be not. Last few days I've been struggling to get a day out of it, it seems. I did a reboot a couple of days ago. Yesterday I plugged it in and had a full charge at 9am; I used it for at most an hour over the course of the day. It was dead when I got up this morning. That's pretty unacceptable.
I did turn off notifications, as I noticed that the screen comes on a bit too often when I move it (it will tell me the time); I also turned off Location, in hopes that it would turn off the gps (why can't it have a simple gps on/off?). What gives? Do I need to turn off cell service? I looked at the battery (under settings), below is the screenshot. All the other services add up to 13%; "Cell standby" is 41% so that only adds up to 54% of battery usage. Where's the rest?
I'm not sure I believe this, under "Cell standby". Pretty sure I have more service than 2% of the time.
Guess I will have to use airplane mode more often; I do have bad cell reception both at home and while in the office. Or perhaps I have a bad phone.
Question: is there an app which will put the phone into airplane mode, and ping the tower say every 15 minutes to see if I have a message? It could revert to normal mode when I enable the screen, but otherwise, instead of being always connected, it could be in more of a standby mode. In case it's a problem of lousy service.
