Originally Posted By: TomYoung
Originally Posted By: 3putter
I think your engine is just worn out. It needs a priest, not an oil change.
I disagree. I think that the oil consumption is within spec. If this were my car, I would use the thinnest oil, synthetic, as allowed in the specificatiuons and try to loosen any gunk. You absolutely must get the PVC replaced and I am not accepting (respectfully) your assertion that it is working properly.
Any modern car that has been properly maintained has a very good chance of having an engine with NEGLIGIBLE wear, even at 200k
The question is. How long has the OP owned the car? If this has been drinking motor oil like I drink Coca-Cola for 10 years there is a very good chance the engine is worn. Most car owners rarely check the oil level and it is very possible the engine was ran and used under very strenuous conditions. Even under the best circumstances, circumstances happens. I bet GHT's car is shot.
